2D drawing chamfer dimmension type
SOLVED
Level 11
Greatings,
 my chef come with an idea, that chmafers should be shown not perpendicular to chamfer surface, but "the linear" shape is correct. See following picture for better immagination:
Does exist some technique or config.pro oprions for setting this?
The only l will never do is: Adding chamfers dimmension manually Smiley Tongue .
have found https://community.ptc.com/t5/Detailing-MBD-MBE/Chamfer-call-out-shown-dimension/m-p/371845#M3202 but it doesnt help Smiley Sad
Have no idea why the chamfer format is a problem, but it is...
Thy in any advice
Regards
@mbonka
1 ACCEPTED SOLUTION
Re: 2D drawing chamfer dimmension type
Hello @MartinHanak
 thanks that you drove me to correct way. Final drw.dtl config settings are:
default_chamf_dim_configuration LINEAR
default_chamf_text_orientation PARALLEL_TO_AND_ABOVE_LEADER
default_chamfer_text DX45
Have a nice day in Přerov...
Regards
@mbonka
with my dtl file I can see this ...
You can open attached drawing created in CR2 M070.
Drawing configuration file contains following options:
default_chamf_dim_configuration LEADER
default_chamfer_text 45XD
Martin Hanák
Hello @MartinHanak
Regards
@mbonka
