3d modification
Level 1
3d modification
The scale range is not clear. Sometime a customer wants to reuse a concept of a design in a much larger part, but to define the size for example 10 times large is not directed possible.
RE: 3d modification
It is possible to use other scaling factors. But you will not find this in the documentation. Example: (K2-UI::sd-set-min-scale-value .1) (K2-UI::sd-set-max-scale-value 10) The question is: why is there such a small a range between .5 to 2?
RE: 3d modification
Often we are asked for simple modifications they are not simple to do. Example: It is necessary to move a face. But - this face should always have the same size and the corresponding faces should change their angle. Look to the picture. Sounds easy, is much work to do.
RE: 3d modification
If you change a blend radius you have a preview after typing a new value. This preview is missing, if you change a chamfer.
3d modification
Often I will be asked how to create patterns from features. One feature has been created, the same feature should be linear or circular on the part. To copy the feature is missing the possibility of setting a numer, a distance, an angle. So the only way is in the most cases to copy the faces as a new facepart, to copy the faceparts (linear or circular) an then insert the faceparts. Could be easier. Regards WoHo
