3d sweep
RV_5434567
7-Bedrock
3d sweep
I'm having a problem with a round bar that needs to be bent in two directions. See pic below.
I thought Creo (3.0 M030) had a 3D sketch feature, which could be used in this case to make a sweep, but I can't seem to find it. Maybe I'm thinking of another program.
Any ideas?
1 ACCEPTED SOLUTION
StephenW
23-Emerald II
(To:RV_5434567)
Create points at each intersection.
Create datum curve thru points (it gives you options on spline or with radius, use the radius option)
Create sweep using that curve.
StephenW
23-Emerald II
(To:RV_5434567)
Thanks, that did the trick indeed. I used two sketches to outline the thing, placed points on each corner, made a curve tr' points and swept it.
One additional question however: is it possible to make a "flat pattern" of this? It's not sheet metal of course, but I need to find out the length of the bar for production.
TomU
(To:RV_5434567)
Just measure the curve length before the sweep.
StephenW
23-Emerald II
(To:RV_5434567)
It's simply the centerline length on tubulars. It's not like sheetmetal where you account for stretch.
