4k Laptop
Contributor
4k Laptop
I'm looking to get a new laptop/notebook and the Lenovo P72 is looking pretty good. I currently use a 6-year old HP Elitebook 8770w.
The P72 has the option of a 4k 17" screen for an extra £400 ($515). Is the extra resolution worth the investment and increased GPU demand for Creo work? I don't really do much rendering so my graphics demands aren't too severe, but I'm often away from my desk so am very dependant on the screen on the laptop itself.
Does the extra resolution mean I can fit more on the screen, and will spend less time zooming about the model, or are the benefits small?
Cheers,
Sam
6 REPLIES 6
Re: 4k Laptop
The higher resolution is only that.  On SOME occasions things might be a little clearer and prevent a zoom, but, mostly, no.
Re: 4k Laptop
The human eye can only distinguish up to so many pixels (DPI) which is like 300. Higher resolutions will help prevent jagged lines at an angle or a circle be crisper.
Re: 4k Laptop
Thanks for the comments.
There is an interesting article suggesting that people with good visual acuity will be able to clearly tell the difference, but I real experience is worth a lot. Does anyone on here use a 4k laptop?
Re: 4k Laptop
I bought a 55" 4k Sony Bravia TV a couple years ago for my home theater and with the right input (I also bought a Sony 4k Blu-Ray player) it's flat amazing.  SRSLY.  BUT, that's for bright color graphics (sci-fi movies) etc..  I also recently read an article that said 4k was basically the limit of the human eye as far as resolution goes, and the only things they can do now to make the visual experience better is increase the contrast (e.g. 4k OLED's), and better color saturation, and a few other tweaks.  So, if you were doing animation, rendering, etc., then yeah I'd certainly recommend 4k, but for doing strictly CAD work, it's probably not worth it.
That said, MAYBE it might be worth getting the 4k, but setting the resolution lower (e.g. 1080p) to speed up graphics and then IF you did any renderings, turn up the resolution to 4k.  Best of both worlds for an added $$ price but it should make regens/spins/zooms faster.
Re: 4k Laptop
I'm starting to think that 4k is a bit of overkill. My eyes are pretty good, so while I might be able to make use of the extra detail, I think I would probably still end up zooming in just as much to make it easier on my eyes over long periods.
Nevertheless, if anyone does have a 4k laptop, I'd be very interested to hear what they think.
Re: 4k Laptop
Oh, and I probably should mention that when I finally get a home CAD system I'm not going to bother with a monitor at all, I'll simply run it thru my home theater system with the 4K big screen and sit on the couch.  At the last job before this one I took the work laptop home for some work and did that and man, that was a great way to work vs a monitor!
