I have a problem. Was created the part (BT-271483) in Creo. The part has an Inheritance of a geometry from another part (BT-271407). Later for the part (BT-271483) was made a drawing. When trying to unload this drawing in the Work area there is an error "Name bt-271407# dr22.prt - not right." In the session I realy see strange part. What is this: ******#dr22.prt ?
Yaroslav, did you try reaching out to PTC tech support with this issue ? It sounds like a software bug, but they will need data to look at.
Did you copy the drawing "BT-271407" to start the drawing "BT-271483"? If that is the case, the new drawing "BT-271483" is still looking for the old model file "BT-271407".
the drawing "BT-271483" was made from scratch. I'll try to contact support.
