AW: summary: WF2 - How to #resume; #by layer ?
Highlighted
Guest
My winner is #1. #2 and 3 are nearly the same with WF2 - functionality (but
more clicks)
1. you can use #applications to switch to legacy-mode, there you can find
the desired command. If it's something you need regularly, a mapkey (+icon
in tool bar) would save you some time.
2. Select Cntrl -F for search dialog box, leave look for and look by as
feature. Go to the Status tab, under rule-selected layer, set the criteria
as either included or not. Then enter a value foe your layer. Select find
know. Pick any or all items selected then close the dialog box. After
which just right click mouse on an empty screen area and choose "delete or
resume". If you use this a lot make a mapkey.
3. With the Find tool, select all feature's in a specific layer, then do
Edit->Resume->Selected
4. I'm taking an intuitive guess....Try right-clicking on the layer name?
Like I said, I'm just guessing, but it's what I'd try.
Thanks for your time Uwe
_____
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
