Accessing Annotation Note Parameters in a part drawing table
Aaron_Daniel
Is there a way to access annotation note parameters (parameters within an Annotation Element Note - not part parameters) in a part drawing table?
1 ACCEPTED SOLUTION
If I understood correctly, all you need to do is to create a parameter of type note and assign the proper note id. Then call that parameter in the drawing.
Take a look at the attached files.
3 REPLIES 3
Can you explain what you wish to accomplish? Typically, the note would be driven by a parameter, not the other way around.
I discovered the reason for my frustration - I had forgotten that to access parameters of annotations, 'NID_' is used instead of 'FID_'
http://www.ptc.com/cs/help/creo_hc/creo20_hc/pma/fundamentals/fund_seven_sub/Syntax_for_Including_Parameters_in_Notes.html#styler-id1.1.1.11.5.7.1
However, my ultimate goal is to find a way to make a parametric revision table in a drawing for a part (preferably using accumulated revision notes under one annotation). It's probably not possible without PTC adding some new report parameter symbols.
Something that most designers seem to want to do is to track the revisions of a part in the model drawing, when it really must be tracked within the model.
As powerful as they are, I find two obvious shortcomings of reports:
a. the lack of ability (report parameter symbols) to track acumulated revisions in part drawings, and
b. the lack of ability (again - report parameter symbols) to create a Parametric Table of Contents for multi-sheet assembly drawings.
http://communities.ptc.com/ideas/2561
