Activate section when sketching
wnicsir
3-Visitor
Hi all,
I'm just wandering if there's a way to activate a section while in the middle of sketching? Sometimes I already sketch something and realized that I need a reference from the cross section. It's such a bummer to leave the sketch and having to activate the section view. I've tried but couldn't find any. I just want to check if it's a dead end from the Creo part or I'm missing something.
Thanks!
1 ACCEPTED SOLUTION
Your desire is not a function of Creo.  But I feel for you.
Mahesh_Sharma
22-Sapphire I
(To:wnicsir)
I think you can activate the X section first and later create sketch. I am referring Creo 4.0
Your question is poorly defined.
If you're working in the sketcher you are sketching on a plane. You have immediate access, there and then, to any other model entity, at any depth, on either side of the sketching plane.
