Add a comment on Repeat Region - First rowalways link to the Region parameters
Visitor
If you want to add comments on a column inside a repeat region, then:
  • When you double clic in the first row you see the parameter from the region = this is KO
  • When you double clic in any other row = you see the correct windows in order to enter text  = this is OK
Allow to double clic in the first row as the other.
