Adding Groups to Family Tables
Highlighted
When adding columns to a family table there is an option to add a column for groups. I have worked for several different companies and this option has always been grayed out (not avaiable). Is this always the case or is there some way to add groups to a family table?
2 REPLIES 2
RE: Adding Groups to Family Tables
The group option actually applies for UDF's used in the part. See this "Suggested Technique": http://www.ptc.com/cs/cs_26/howto/fun521/fun521.htm If you want to add a local group to your family table, just add it as a feature.
Thanks, that helps a lot.
