Adding Relation in repeat region table
vijay
1-Newbie
  • In a repeat region family table shown in below image, "N" has to replaced with "-". Is it possible to replace "N" with "-" only in detail drawing whereas the model with family table uses "N"?
  • How to write the relation?
4 REPLIES 4
dschenken
(To:vijay)
You need to do two things: create new parameters and then use them.
The reason is that you can't over-write/change model parameters within the repeat region, so you need to create new ones that represent the result you want. Then you use the repeat region parameters you made in the region and not the original model parameters.
If the model parameter was: ITEM_NAME and you wanted ITEM_NAME to be used unless it was "N" you would use a relation like:
rpt_item_name = ITEM_NAME
if rpt_item_name =="N"
rpt_item_name = "-"
endif
In the repeat region instead of using asm.mbr.ITEM_NAME, use rpt.rel.rpt_item_name
I recommend using "rpt_" as a prefix for the new parameter names to make it easier to identify the relationship to the original parameter.
I think rpt_item_name = ITEM_NAME line is not correct. Use rpt_item_name = asm_mbr_ITEM_NAME
MH
Martin Hanák
I'm going to cheat and suggest that ITEM_NAME was the full, qualified name, but your suggestion does make it easier to understand.
At least I got it right half the time.
MartinHanak
24-Ruby II
(To:vijay)
I think wanted solution depends on repeat region representation. I guess you created Two-D repeat region ...
Please upload data for testing purposes. This helps us to find the proper resolution of your problem.
Use How to Attach a File to a Discussion Reply procedure
MH
Martin Hanák
