Adding a Column to Table
Robert-Altman
7-Bedrock
Have a user trying to add a column to a table with repeat regions, when
we do the repeat region now spans two columns.
Is there a particular technique where I can add a empty column to the
table? I have tried picking on different places along the edge of the
last column.
Below you can see that the repeat region is spanning two columns
This what I want, a new column that I can now add a repeat region to
The only way we have been able to do it is to delete the region add the
column and then recreate the two regions.
Thanks in advance,
That's the only way I know to do it too.Copy the filter out of the column that's beenadded to so you can paste it back, a small time saver so not to have to recreate that at least after deletingand recreating the region.
