Analysis feature
Garnet
Analysis feature
I have created an analysis feature to measure surface area. Now I want
to display the area on a drawing. How do I get this information to come
across to the drawing?
Bill
Analysis feature
Bill,
While you are creating the analysis feature (area_analysis, for
example), be sure to create a feature parameter (surface_area, for
example) within the analysis feature. On your drawing, add a note with
the text "&surface_area:fid_area_analysis:X" where X is the session id
of the model that contains the analysis feature. I believe "fid" stands
for "feature id", or at least that's how I remember it.
Hope this helps,
Tyler
WF2
Analysis Feature
WF3
OK, I must be a moron, how do I create an analysis feature in WF3?  I click the 'Analysis' icon or I click Insert - Model Datum - Analysis and the analysis box comes up.  So far so good, just like WF2.
Now, I can name it (which never seems to take, so I skip it) and then I select the type.  I can choose UDA, Relation, Excel Analysis or Mechanica.  Odd, in WF2 I have a Measure and Model Analysis too, which is what I usually use.  So, I'm not using Excel or Mechanica, so that leaves UDA or Relation.  UDA gives me an error "There are no UDA local groups in current model." and won't let me do anything else, and Relation takes me straight to the relations editor, which isn't real helpful.
What the heck am I doing wrong here?
Doug Schaefer
LinkedIn
