Hola -
I'm sure someone, somewhere, who if far more clever than me has figured this out.
I'm trying to drive sketch dimensions from an analysys feature (Excel). I can create the feature, I can read in the data from Excel, Pro (Wildfire 4) creates the analysys feature parameter (XL_12_2, etc). I run "Compute" and the data updates....all seems right in the world.
However, when try to write a relation, or a sketch relation, I have no access to this data - it just doesn't appear.
Any and all help greatly appreciated!
TIA.
The parameters created by the analysis feature islocated in the analysis feature itself.
For instance
If you were driving a length value with the following values
Dimension name in sketch - SKETCHEDLENGTH)
Analysis feature id: CONTROLLENGTH
The relation would be:
