Any solution in Hole Table auto update options in Creo 2.0?
SOLVED
Guest
Hi everyone,
Can anyone please let me know, if there is any option to auto update in created hole table, if i updating th hole parameters (like dia, positions).
Santhosh,
Re: Any solution in Hole Table auto update options in Creo 2.0?
I do not know if there is an option for auto updating hole tables, but be very careful using Hole Tables. You definitely want to double check the results against the model. I have had issues with holes not appearing in the table when they should.
Dave Martin - dmartin@creowindchill.com - https://www.creowindchill.com
