Any way to convert a centerline object into geometry?
Garnet
Hello community,
I'm experiencing hard troubles in translating (...) a MI file into DWG. Several tests made me guess that the problem must come from parts containing Centerline objects. I'm seeking for a way to convert them to geometry, but had no luck up till now. Macro instructions to replace the objects would not do, since I have, for instance, dimensions attached to them. The dxfdwg.con file does not contain any setting about this matter.
Disconsolately thanking for attention,
Marco
Re: Any way to convert a centerline object into geometry?
What would be the Modeling version you're working in. i thought there where issues with version 19.0 M010 so perhaps you should try updating your modeling version
Hy Ward and thank you: the version is just M010.
As I noticed in recent tests the problem seemed at first to be restricted to the Bolt circle feature: in a simple drawing the creation of a Bolt circle made the translation impossible. But testing on with a complex drawing, I found out the problem persisting until deletion of all Centerlines in details that containded at first Bolt circles too.
At the moment I cannot get version upgrades and must manage the matter in some other way.
