Anyone have the PreWF graphics settings??
abesau
2-Guest
Anyone have a pre WF graphics settings??  syscol.scl??
That dark blue background.
Also, the old yellow/red datum planes.
I'm talking about ProE R17 times.
Feeling retro.
7 REPLIES 7
mganzer
(To:abesau)
I do but how do we attach a file? Create a ".scl" file and paste this in:
COLOR_SCHEME 8
USE_PRE_WILDFIRE_ENTITY_COLOR YES
SYSTEM_BACKGROUND_COLOR 0.000000 7.058824 19.607843
SYSTEM_DIMMED_MENU_COLOR 70.980392 70.980392 70.980392
SYSTEM_LETTER_COLOR 100.000000 100.000000 0.000000
SYSTEM_HIGHLIGHT_COLOR 61.176471 0.000000 21.568627
SYSTEM_EDGE_HIGH_COLOR 0.000000 0.000000 100.000000
SYSTEM_GEOMETRY_COLOR 100.000000 100.000000 100.000000
SYSTEM_HIDDEN_COLOR 40.000000 40.000000 40.000000
SYSTEM_SHEETMETAL_COLOR 0.000000 100.000000 0.000000
SYSTEM_CURVES_COLOR 100.000000 67.058824 0.000000
SYSTEM_VOLUME_COLOR 100.000000 0.000000 100.000000
SYSTEM_SECTION_COLOR 34.901961 72.156863 100.000000
SYSTEM_PRESEL_HIGHLIGHT_COLOR 0.000000 100.000000 100.000000
SYSTEM_SELECTED_COLOR 100.000000 0.000000 0.000000
SYSTEM_SECONDARY_SELECTED_COLOR 100.000000 47.843137 0.000000
SYSTEM_PREVIEW_GEOM_COLOR 98.431373 100.000000 70.196078
SYSTEM_SECONDARY_PREVIEW_COLOR 70.980392 70.980392 70.980392
SYSTEM_DATUM_COLOR 60.000000 45.490196 19.607843
SYSTEM_QUILT_COLOR 58.039216 0.000000 70.196078
UI_EDITABLE_AREA_COLOR default
UI_SELECTED_AREA_COLOR default
UI_BACKGROUND_COLOR default
UI_SELECTED_TEXT_COLOR default
UI_TEXT_COLOR default
BLENDED_BACKGROUND yes
SYSTEM_TOP_BLENDING_COLOR 0.000000 36.470588 60.784314
SYSTEM_BOTTOM_BLENDING_COLOR 0.000000 6.666667 19.607843
Found the attach button...
Thanks Mark!  The background is not exactly what I was looking for, but i'll do.
TomD.inPDX
(To:abesau)
Here's another you might try...
COLOR_SCHEME 0
SYSTEM_DIMMED_MENU_COLOR 57.8125 57.8125 59.765625
SYSTEM_LETTER_COLOR 100.0 79.6875 19.921875
SYSTEM_HIGHLIGHT_COLOR 39.84375 7.8125 7.8125
SYSTEM_EDGE_HIGH_COLOR 100.0 14.84375 14.84375
SYSTEM_GEOMETRY_COLOR 94.53125 94.53125 97.65625
SYSTEM_HIDDEN_COLOR 75.78125 75.78125 79.6875
SYSTEM_SHEETMETAL_COLOR 7.8125 39.84375 7.8125
SYSTEM_CURVES_COLOR 19.921875 19.921875 59.765625
SYSTEM_VOLUME_COLOR 39.84375 19.921875 39.84375
SYSTEM_SECTION_COLOR 19.921875 79.6875 100.0
SYSTEM_PRESEL_HIGHLIGHT_COLOR 39.84375 100.0 19.921875
SYSTEM_SELECTED_COLOR 19.921875 79.6875 39.84375
SYSTEM_SECONDARY_SELECTED_COLOR 19.921875 79.6875 79.6875
SYSTEM_PREVIEW_GEOM_COLOR 100.0 54.6875 0.0
SYSTEM_SECONDARY_PREVIEW_COLOR 79.6875 39.84375 59.765625
SYSTEM_DATUM_COLOR 59.765625 39.84375 19.921875
SYSTEM_QUILT_COLOR 100.0 79.6875 19.921875
SYSTEM_SHADED_EDGE_COLOR 4.6875 4.6875 5.078125
SYSTEM_BACKGROUND_COLOR 0.0 0.0 19.921875
SYSTEM_TOP_BLENDING_COLOR 0.0 0.0 23.4375
SYSTEM_BOTTOM_BLENDING_COLOR 0.0 0.0 11.71875
Mark, where did you find the UI_* options for the color file?
I remember there were two places you had to select the colors. One is the System Colors in the Customize GUI. I can't seem to find the second location. I wonder if it was dropped in Creo, so the other setting was in WF 5?
Thanks Mark.  Glad you captured that.  I will have to see if it affects Creo.
