Trying to figure out the new Text Note Feature Control Frame. For legacy drawings PTC suggests applying drawing update 2202279. PTC neglects to tell you how to do this. Does anyone know?
Thank you, I found this information specifically for 2202279 which fixes the following Text Note GD&T:
1. Open the drawing in Creo
a. Select File>Prepare>Drawing Properties
b. Under Detail Options, select change
i. In the Option field, enter update_drawing
ii. In the Value field, enter 2202279
c. Select Add/Change>Apply>Close
d. Close the Properties Window
2. In the Review tab of the drawing
a. Select Update Sheets
Thanks for spelling that out for us, Don.
