"Scott Jones" wrote:
Hi, You need to create a search.pro which is essentially a text document listing all of the folders where you keep you ProE files. I keep my search.pro in the start directory (same location as your config.pro). My text document consists of the following lines of text:- "k:\Proe Library\Fasteners" "k:\Proe Library\BOM Tables" "k:\Proe Library\symbols" "k:\Proe Library\Templates" "k:\Proe Library\Flashing T5" "k:\Proe Library\Scott" "k:\Proe Library\Seat" "k:\Proe Library\Extrusion" "C:\My Documents" When Proe opens your assembly it will look for a search.pro in your start directory and then just run through the list of specified locations. Create the file in notepad or wordpad and when finished make sure you name it a search.pro and not a search.txt (rename the document .pro) Hope this helps! And I hope it's right! Scott
"Reinhard Nueckel" wrote:
its the full path to your folder including the drive. Additionally you have to tell ProE where to find your search.pro by a line in your config.pro like search_path_file your_search.pro_with_path
