Auto coloring in Creo Parametric
Granite
Kind of need information on auto coloring in creo parametric,
Now consider I'm dealing with a large number of cables or wires in creo parametric. And I need to assign different colors for each cable. Rendering colors to each cable kills my time.
I have an Excel sheet which states the variation of colors for different cables.
Now
1) Can I make Autocoloring using the Excel sheet (maybe using that sheet  in XML format)
2) Does pro-e programming help me on this?
Thank you.
Re: Auto coloring in Creo Parametric
No autocoloring in Creo unless you assign color to a material, then set your material.
I would think the effort to write the pro-program would be harder than just assigning a color to each cable type as you create them.
