Axes not showing in Drawing
TomK_MN
7-Bedrock
Model Axes not showing up in Drawing
Tried turning on/off in View
Tried changing Config to yes & all sub
Tried hide/show in Model tree
I can see them briefly if I rotate View Type with the Angles toggle but they disappear after clicking OK.
all other datum feature show up fine
1 ACCEPTED SOLUTION
StephenW
23-Emerald II
(To:TomK_MN)
Just like dimensions from the model, you have to show axis.
Go to the annotation tab, then the show model annotations button, then click the feature or view you want to show the axis from the model.
StephenW
23-Emerald II
(To:TomK_MN)
Thank you!
Where I was clicking it was selecting the feature instead of the view, so Show Model Annotations was showing no annotations.
