lucky you, I'm still struguling with this. here is the scenario 1. make unattached wall 2. Then add flange wall 3. on the flange wall I make rectangular cut for example 4. then add the axis point by adding constrains (attaching it for the symetry axis of the rectang) 5. then do unbending (fixing some other surface, not the one where is the holes) 6. and axis is not with the hole anymore. 7. crazy However, round holes are not showing this issus, but any other shape of hole does.
