Basic question about drawing
ptc-5675800
1-Newbie
Hello all,
My question is about drawing. It is a basic question, but I can't figure it out :
I made a drawing of a part (so far easy...) :
1. I have enabled the plan view : Why are there a red and yellow line ?
2. I would like to draw a line, taking the plan as a reference : is it possible ?
Thanks a lot for your help,
1 ACCEPTED SOLUTION
select the particular plane part
right click and select properties
select either ansi or iso datum
now when you see the plane in drawing
it will be a single line with the datum symbol
offcourse you still have to hide the planes from the display filters.
7 REPLIES 7
that is the datum plane. the front and back of a plane is shown in two different colors.
go to display filters and uncheck the datum planes.
Thanks.
I would like to keep the datum planes on my drawing.
Is it possible to represent the plane by just one color/line ?
yes you can by converting it into a model datum
Thanks Rohit,
How would you do that?
Thanks !
happy to help!
