Blue Cross Sections??
Regular Member
Hey all,
Just went from 5.0 to 6.0.1.0 and now when we edit definitions while a cross section is activated. We get a blue cross section color. Like the whole section is blue with no definitive part outlines to be seen. Pretty terrible when trying to re-constrain interior parts of an assembly.
Anyone else run into this or know of a way to change how an X-Section looks?
Re: Blue Cross Sections??
I don't know if it's done the same way in the latest Creo, but there is a file I use to define specific colors for things, called "syscol.scl".
Inside that file is a line that says
alias_sec_dim_strong_color_to   system_letter_color
And to use that file I have a callout in my "config.pro" file that states
system_colors_file  c:\ptc\DefaultFiles\syscol.scl
The trouble with color specifications is it's like an arcane art. There isn't anywhere that I've been able to find where you can get a list of the things you can specify in the "syscol.scl" file and what they mean. Any other specifications I've set were copied from other people's files, etc.
If anyone knows of  a reference somewhere from the dark recesses of time that gives me a list of these things, it would be really helpful...
I've tried changing all the colors in appearances that were the blue color, to something else. To no avail...
Also gone into the Syscol.scl file and tried changing the "SYSTEM_SECTION_COLOR" This did not change the blue when editing components with the cross section active...
