dear;
hope you all are doing well
currently this how our cnc cam sheet looks like
in this you can see the numbering and programme order has to be read from bottom to top , I want to make it from top to bottom . please help
Select a table and change table properties.
I am using creo 3 ,I need by default pgm details in water flow order .
below image file is my cam sheet template , I cannot find sort index option in creo 3
You have to change Table growth direction. Select a table and change table properties.
I think you would need:
Please, next time open a new discussion, if you need to solve a problem .
MH
sorry sir;
its not working
