CAM SHEET (DRAFT) CUSTOMIZATION
Sreemesh
6-Contributor
dear;
hope you all are doing well
currently this how our cnc cam sheet looks like
in this you can see the numbering and programme order has to be read from bottom to top , I want to make it from top to bottom . please help
4 REPLIES 4
Select a table and change table properties.
Martin Hanák
Sreemesh
6-Contributor
(To:Sreemesh)
I am using creo 3 ,I need by default pgm details in water flow order .
below image file is my cam sheet template , I cannot find sort index option in creo 3
You have to change Table growth direction. Select a table and change table properties.
I think you would need:
  • to split Repeat Region table from the existing table
  • to move Repeat Region table manually if you add/remove a component to/from the assembly
Please, next time open a new discussion, if you need to solve a problem .
MH
Martin Hanák
Sreemesh
6-Contributor
(To:Sreemesh)
sorry sir;
its not working
