CONFIG SETTINGS
SOLVED
Participant
CONFIG SETTINGS
How to set our config.pro setting file and color file .scl as by default?
Re: CONFIG SETTINGS
Martin gave you the answer on the system colors.  Creo will automatically load a config.pro file from these locations, in this order:
  1. The text folder in the Creo installation.  By default this is something like C:\Program Files\PTC\Creo 3.0\M150\Common Files\text
  2. The user's home directory, as defined by windows environment variable
  3. The "start in" folder as defined in the properties for the shortcut used to launch Creo.
Put it in any of those folders and it will load automatically.  If Creo finds more than one, they are applied cumulatively.  If any options conflict, the last one loaded is applied.
Lastly, there is a special config file that you can use named config.sup.  It must be in the text folder and, if found, will be loaded first. Any options found in that file cannot be overridden by other files or by the user after startup.  Used for company standards, but it's wise to keep this file to a minimum.
Doug Schaefer | Engineering Manager
Crow Works
Re: CONFIG SETTINGS
add system_colors_file option into config.pro, for example
system_colors_file F:\users\mh\tmp\creo1_parametric\syscol_crp_mh2.scl
Martin Hanák
Re: CONFIG SETTINGS
Crow Works
