Prior to WF 5.0, I could create and axis in the sketcher mode by the commands sketch/axis point. The user then could place a point onto the sketch (say the center of a slot) and then after the feature was created the slot would have a 3d axis that bolts and holes could be aligned to.
Wheredid the command go inWF5.0?
As for PTC customer/user service,
When is the Menu Mapper from 4.0 to 5.0 going to show up on the PTC page?
Where are the release note located on the PTC websight?
In the sketcher use the point creation icon for creating an axis. There are two types now and the "geometry point" is the one you want to create an axis in your sketch that is normal to the sketching plane. Happy modeling
Mark A. Peterson Sr Design Engineer Igloo Products Corp -
