Can't press "boundary blend" - button
ptc-2990591
Hello I have Pro/E Schools edition (WF 4, latest relase). I can't press boundary blend button, no matter what i do. The button is always "gray" (like round or camfer button when there is nothing to round / camfer). I tried to select two and three curves (sketch). I also tried to create datum curves, select solid part edges... Any help would be welcome...
5 REPLIES 5
Did you already go in Featurize mode? Wachayu Sweathamal
Thanks for your reply! This may be rather newbie guestion but how do I enter featurize mode? Also, I can't find "surface" tool anywhere. I've only used WF 3 before. Thanks for help!
You must be in part modelling and have at least some curves to be used as boundaries or at least one solid feature for solid edges to be used as boundaries. I never used an educational vertion but if still don't work you might have lisence limitations.
I tested this with curves and surfaces and other kind stuff... Does anyone know if school edition has license limitations? Thanks for replies!
I have same problem too...please help us:(
