Can't remove material
Highlighted
Regular Member
Assigned material appearance
In model properties, Material, I can have different appearance for a material. For example I have copper that is polished and another that is brushed. Then in my Model Tree I have a column PTC_MATERIAL_NAME that shows the material. So how can I show and choose the different material appearances?
1 REPLY 1
Re: Can't remove material
I think you have to create two materials - one for polished copper and second for brushed copper - and switch between them.
Also appearance definitions should be placed in graphic-library\appearances\global.dmt file.
Martin Hanák
