I built a new template model that included 4 variations for machined, non-machined, holes removed and simulation states.
After submitting the template I wanted to cross check it. When I go to open the template I see that all family table instances are available for picking.
I chose the generic. I went to family table to check the other instances. There was no family table in the model that once had a family table.
By any chance is there a way to get the family table to work in a template?
The work around of course is to save the file to a specific location and do a file save as, but the template interface is more streamlined.
Does the Family Table in the template have any columns? I wonder if that makes a difference.
Is there a reason you're going with a Family Table instead of Inheritance Models for the non-machined and holes removed versions? Inheritance is a lot "lighter" when it comes to CAD data management. And I'm partial to Part Simplified Reps for simulation models.
Dave;
It would certainly work in using Inheritance Models but from our experience this doesn't integrate well with changes.
There are a lot of ways to attack a problem. Sometimes a specific method would work well with a certain type of model but not another. Sometimes holes in the learning process leave opportunities for better opportunities. For instance I've not even touched simplified reps that you mentioned.
I personally love the family table when applicable, I like copy geom for copying extensive quilts, and only grudgingly use inheritance modeling when we have to integrate a solid model into another.
What I hate about Inheritance Modeling is that once you change the name of models (as in revisions) it can't find the model and you have to reinsert the model and hope the downstream feature history doesn't go haywire.
In this application Merge Inheritance would work well with one of the parts, but not with the others as there would be requirements for going backwards in the original model to get to the level necessary, and then you don't have the feature tree to do adds and subtracts. I also don't like having multiple models if not necessary.
I like adding and subtacting features as needed as in the family table.
I don't believe part templates work with family tables. There would be a lot of file name management that the Creo New command just isn't built to handle. Here's some ideas:
I forgot about the road block here that I encountered earlier.
I just put a considerable amount of work into creating a new template file that has a family table.
Today I went in to use the template file and was confused why the family table did not come across.
When importing the template model I can see that every element of my family table is in there.
I see the generic with all of the sub sets.
If I tab over to "by column" I can see that all of the differentiation is accounted for.
It would really seem that you should be able to bring in a template model with it's fully functional family table as everything seems to be there to bring in.
I just want to revisit this topic to see if there might be a way to bring in the complete template model.
Once again; I can save the above needed model file in a specific location but using the template insertion interface is a lot more streamlined.
The issue is probably that even if you change the name of the generic when you copy it from the template, the INSTANCES in the table remain the same name and Windchill will not allow that. You could use parameters to change the "NAME" and "NUMBER" parameters but I don't know if there's a way to change the actual filename that way.
We don't use Windchill so I'm not exactly sure how that would work.
When you do a File Save As however it does allow you to copy the entire structure even if the family table item names remain the same. Granted; things become unhappy if I'm in the same directory and haven't changed the file names of the family table members. I do eventually rename all the members to correlate to the job number of the main file name.
So perhaps there would be complications if used in conjunction with Windchill yet you can do essentially the same thing with a File Save As.
If you're trying to save in the same directory as the template Creo probably still knows it's a duplicate filename.
Yes, even though the main part name is different when the family table components are the same it gets tangled up. Even with trials I'll rename the family table instances.
If the reason you can't drive a template with family table instances is a naming issue I wonder if there might be a way around that.
I'd submit this as an idea but since I started using Creo many years ago none of my ideas got any traction even though there were others that liked the ideas.
Well, the way around the naming issue is using Windchill if I remember. Haven't done it in a long while but if I remember, doing a "Save As" at the Windchill level allows you to rename all the instances at the same time. The fact that Windchill remembers all the links is THE best reason to use it vs. just saving to a PC drive.
VERIFIED: When doing a "Save AS" in Windchill, if you "Collect" the family table objects, you can rename them all, including the instances, so that there is not a duplicate filename issue.
This is something I GUARANTEE that PTC will not change because they'll just push you to buy Windchill and tell you that's the fix....and they would be right.
Frank: Thank you for verifying this.
I can see the renaming point to an extent yet every time you do a file save as you run into this possibility and I've waded through that potential issue without any problems. I can see that you are probably correct that they will not change this as it does control reuse of names.
Our company would never flip the penny for Windchill. It's hard to meet the small company budget constraints as it is. This has the typical feel of the way their software licensing is split up to give them more revenue. You have to have a seat of this in order for that to work. I like the software but hate the licensing.
Yeah, I hear ya. ME, I hate Windchill, but we've been forced into it by PTC when they purposely made Creo incompatible with the MUCH more stable and easier to use PDMLink. They REALLY need to offer a solution for you smaller businesses. A Windchill that doesn't have the PLM cr@p in there hardly anyone uses anyways. A bare-bones Windchill just for vaulting Creo files and associated PDF's, Word doc's, etc.
Not like they care though...
