I reference a part number in a note on my drawing. The same part number is also referenced in a table. I wanted to somehow link the two part numbers so that if I change the part number in the table it will automatically change in the note. Is this possible?
in Creo Parametric 2.0 you can create parameter in part and call out this parameter in drawing note/table cell.
See uploaded data:
1.]
In ref_part_name.prt there is a relation pname=rel_model_name() which defines parameter pname.
2.]
In ref_part_name.drw tha parameter is called using &pname notation.
Martin Hanak
