Can you create a drop down list for parameters in Creo?
SOLVED
Re: Can you create a drop down list for parameters in Creo?
I have a similar need for cascading restricted parameters.  This would be GREAT for an enhancement (Hint hint PTC).  You can do this in Windchill but not in CREO 4.
There's a way to do this in ModelCHECK check but will take a lot of tricky configuration to make this happen.
This should be an OOTB functionality.  Solidwork does this today and a few automations that should be easy to implement.
Highlighted
is looks correct to me, just like scripting, you need to make sure you have the match open "{" with the close "}" and commas.
Good luck!
