Cannot Unbend or Create Flat Pattern
CJK_Acuity
Help please! This model will not flat pattern or unbend. All radii seem to be constant and the part is fairly basic. Can anyone see what the problem is? I'm in creo elements/pro 5.0
1 ACCEPTED SOLUTION
The problem is in your first two Bend features. The radius cuts slightly into the main bottom surface. You can either adjust the distance or create a Rip inside the Bend features.
I'm on Creo Parametric 2.0 so can only provide screenshot from this release. Note Form features are suppressed due to missing reference models.
Thank you much!
Your part is actually set to the default relative accuracy of .0012. Changing this to absolute at .0005 will also resolve your model.
Have a look at this discussion: http://communities.ptc.com/message/260507#260507
Default sheetmetal part template values are absolute .0005 for inch and 0.0125 for metric.
Remember that you have to enable absolute accuracy in config options or config.pro
enable_absolute_accuracy yes
You can do this option in session.
Also see default_abs_accuracy and accuracy_lower_ bound
