Cannot extrude simple Square
ElonMusk
3-Visitor
Hey I have made this square using symmetry and for some reasons Creo doesn't recognize it as a closed loop(but doesn't tell me where) and won't let me extrude it....does anyone know why this is?
I have attached a photo; for some reason I couldn t attach the source file though
5 REPLIES 5
I guess that your section contains overlapping lines.
Note: If you want to upload mypart.prt.1 then I suggest you to pack it into zip file, eg.  mypart.zip and attach this zip file to your reply.
Martin Hanák
Well the problem that Creo doesn't show me any intersecting lines and I don t see how there can be any, as it is such an easy form. I have attached the source file below 😉
unfortunatelly I cannot unpack your rar file. Please upload zip file.
Martin Hanák
Alright it should be good now.
Thanks for helping me btw 😉
StephenW
23-Emerald II
(To:ElonMusk)
On something simple, I will typically just delete a line at a time and undo until I find the one that i sketched twice.
Or more likely, I will just delete all of them and resketch. For a rectangle, use the rectangle sketch so you don't accidentally double up a line or the arrow next to the rectangle to get a centered rectangle.
