I'm having the problem that I am unable to flip the chain direction in a boundary blend.
The flip button is greyed out.
My guess is that this is only used with something like a VSS where the direction along the trajectory curve is specified.
Hello MAARTEN MEYNS
try to check sketch "second reference" for 1st and 2nd chain. This reference should be the same for both.
Not sure, if it will help you... it´s the first what came to my mind.
Regards
