Cannot hide quilt - thread lines in cross section
SOLVED
Highlighted
Newbie
I do not know how and why this is happening. I have M080 running. I cannot hide threads lines and "hidden line removal for quilt" is grayed out.
Tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: Cannot hide quilt - thread lines in cross section
I have WF5/creo, and so it looks like you have different options. There's several settings that affect quilts, the one I mentioned, the one you mentioned, and there are some dwg (.dtl file) options also:
remove_cosms_from_xsecs yes
show quilts in total xsecs no
hlr for threads yes
thread _standard std_ansi_imp_assy
Hopefully these will get you what you want.
12 REPLIES 12
Highlighted
In your config.pro, try setting: hlr_for_quilts yes
Highlighted
Frank, I just got off the phone with PTC and the setting I had to change was "show_quilts_in_total_xsecs YES" in drawing properties. I also included your setting as well under conffig.pro. Just in case. You never know with Creo ...
One more thing. They told me if cross section is made without option "Include all qults" under Options tab, option "hidden line removal for quilts" will be grayed out as it was in my previous post.
Highlighted
hlr for threads yes
Highlighted
It was this one:
remove_cosms_from_xsecs all
Thank you everyone!
Highlighted
HOLD ON EVERYONE!
Actually, just both of us, Frank.
Forget what I wrote in previous posts. I found out this by pure "click" mistake. None of those previous settings work, but this one works for sure:click.png
Highlighted
Actually, this just removes cosmetics on every hole. BLAH! Still looking.
Highlighted
After changing "hlr_for_quilts yes" did you redo the section? (change to No Section, apply, then pick the section again.).
Highlighted
Matt, I even redo the whole cross section again and it did not help.
Highlighted
Hi Danilo !
Your post helped me a lot !
Thanks for sharing !!!
Highlighted
You are welcome.
Highlighted
There is a BUG in Creo when working with cross sections and "LOCAL" option is selected. Everyhing works fine with cross section option "FULL". I guess, PTC does not have a way to disable this BUG as an option .
Highlighted
And then, my productivity went down, trying to find a solution for quirks Creo has ... that shouldn't be there in first place. Does anyone checks anything in PTC prior release?
