How to get total chamfer features available into components of assembly ?
I tried to use search criteria and could find out option for revolve and extrude. but could not find option for chamfer.
Search can help you to get the count.
Search > Look for and Look by Feature > Type > Value Round/Chamfer
If you will build a query, you will get count in one search.
Edit: attached a quick video for steps..
Rounds/Chamfer are not available in assembly mode. There is an existing idea for the same. Vote the idea at https://community.ptc.com/t5/Creo-Parametric-Ideas/Allow-fillets-rounds-chamfers-in-assembly-mode/idi-p/461061
Don't know what you mean by "total chamfer". The only features you can create in assemblies are hole, extrude, and revolve. Additionally, the extrude and revolves can only be used to do material removals. You can't make chamfers or rounds. Those need to be done in the part models.
Making assembly cuts is not something most people do unless they absolutely have to because in the past it has tended to behave strangely, especially if you add components to your assembly after adding the cut. It's considered to be bad practice for most situations. Part reusability is one very good reason, for example.
*facepalm*
