Chamfer/Round
Highlighted
Newbie
Chamfer/Round
Morning All
I am trying to create a round or chamfer in the area marked with no success, the rib is just touching a sphere. Any ideas?
The model is attached.
Tags (2)
8 REPLIES 8
Highlighted
Re: Chamfer/Round
try to reorder the rounds. The smaller rounds on the ribs can be added after the chamfer or the round that you are trying to create.
Highlighted
Re: Chamfer/Round
Hi Manjunath
I still cannot create a chamfer or round at this point. I deleted all the chamfers and rounds and tried a different order but no luck.
Any pointers?
Highlighted
Re: Chamfer/Round
See attached part. I had to edit the Extrude_5 and re-add the rounds around...
Highlighted
Re: Chamfer/Round
Thanks MRV
What was wrong with Extrude_5 to cause that problem? I could see a step but it was very small.
Regards
Phil
Re: Chamfer/Round
That curve in the sketch was a spline and the end was not aligned properly to the ends of the revolve. I replaced that spline by projecting the edge of the Revolve.
Highlighted
Re: Chamfer/Round
Another edge that refuses a round!
I cannot get this inside edge to take a round.
Highlighted
Re: Chamfer/Round
That was easy one....
Highlighted
Re: Chamfer/Round
Hi MRV
Yes I forgot to use variable round and it works!
Regards
Phil
LiveWorx Call For Papers Happening Now!
