I have done a model with ProE default template. Now I want to change the template to another.
Is there a quick-fix? Or do I have to model the part again? 😕
There is no way to change template...
If model isn´t to much complicated (and templates are similar) try following:
1. start new part with new template
2. open old part and copy all featers (mark them all in model tree and CTRL+C)
3. open new part and paste featers (CTRL+V) --- confirm new references
Simply copy all featers from old part to new part.
Thanks Milan
Just the answer I wanted
