Closing sweeps ends
SOLVED
Highlighted
Regular Member
Closing sweeps ends
Recently, in my work I have to do a lot of sweeps, like the one bellow:
Now, to close the ends I have to do a revolve:
This doesn´t seem much work, but, to do the revolve it takes about 23 clicks (Revolve, Select Plane for skecth, add references, define axis, project, trim...) for each end. Total of 46 clicks for closing both sides.
I´m trying to figure out a easier way to do this. I tried copy/paste and udf´s , but both fail often.
Jose
1 ACCEPTED SOLUTION
Highlighted
Re: Closing sweeps ends
Ok, I found a solution, maybe can be shortened a little but it´s the best I´ve got for now:
1 - Do the sweep
2 - Copy one end surface
3 - Trim it by half (by plane)
4 - Copy all edges of this surface
5 - Create a revolve using this edges
6 - Repeat in the other end.
Grouping it all together I just have to give 4 references for each runner: a curve, one end, other end and a normal plane.
I reduced from about 50 clicks to 5 or 6. Good enough for me.
Video Link : 5294
20 REPLIES 20
Highlighted
If you don't mind a small pip, a round does pretty well.
...and it can be C2 continuous.
Highlighted
Since this is a channel to be milled, I have to keep the profile (angle and radius):
Nice pic, Huh??
Highlighted
I got to this within a few hundred... maybe a 1,000 clicks
Only few hundred more clicks might have achieved round'r ends.
I'm proud of it though... fully bound with curvature contraints!
Of course, you could sweep the 1/2 profile around the periphery .
Highlighted
Excellent idea! 1 feature, nice!
Highlighted
I can see Frank's little mind-minions at work already...
Frank Schiavone - little minion cloud:
...How can I turn that into a VSS -AND- Spinal Bend... Mu-hahahaaaa!
Highlighted
Hah! You know me too well bro! I tried a VSS, figuring it would fail because the section became normal to the spine...and it did. Would be cool if it'd worked...... BUT...the full round is a more powerful tool than people think, it didn't work in this case (for some odd reason, maybe because the end surfs are angled), but if you add a radius to the end lines (ends normal to the sweep), then do a full round, you'd be surprised at how well that works.
Highlighted
You´re right, It can be done that way, but it´s much more complex to draw the boundaries instead of the centerlines. It´s a solution that I can´t use.
Highlighted
You do not have the mold design package I am guessing?
Highlighted
Yes I have, I can create runners with it, but...... the runner only allows to create cuts, not create "extrudes", I need to create the solid of the runners first, and then make a cut-out.
Also the runner feature seems to have some bugs.
Highlighted
Ahhh, runners. Remember when you got a plastic model to put together, and there was more total material in the runners than the parts?
Highlighted
Ok, can you do it backwards? create the channels first and then copy the surfaces to create your extrude version?
And not sure what bugs you have with runner tool, it seems to be one of the few that work really well in the mold package for me.
Highlighted
...or All-in-One
Highlighted
I may be off topic a little here, but thought this was worth a mention. I create a lot of channels cut into solid blocks, very similar in profile to Jose's. I had the same problem, how to round off the ends, to actually reproduce what a milling cutter would give. My approach is to use the hole feature, specifically 'hole on point placement'. Within the hole feature, you have the option to sketch a hole, sketch 'half' the profile in the same way you would, if doing a revolve end. I have placed datum points at each end of my sweep curve (geometry points added to the curve itself, cuts down on model tree features), select one for hole placement, & voila! you have a rounded end. What brings this into its own, is if you have multiple ends to do, you just copy & paste, selecting a new datum point for another end. Hopefully, the attached model & image explain my approach further.Capture.JPG
Regards
John
Highlighted
I was looking for that sketched hole in Creo 2 but didn't see at at a glance. Hope it is still there somewhere.
edit: phew.... yep, still there
Highlighted
Nice, that´s something that I didn´t try. It´s a much more easy way to get it done.
But I see 2 disadvantages there:
1 - Dimensions of the hole aren´t constrained with the dimensions of the sweep. If you need to adjust values, you need to do it in three features.
2 - It´s only possible to remove material, not to add.
But a good option, no doubt about that.
Jose
Highlighted
Hi, with regards to point 1, you could link the hole dimensions to the sweep dimensions by relation, thats what i do.
John
Highlighted
1 - Do the sweep
Video Link : 5294
Highlighted
That was my initial method as well, Jose, but I ended up with 23 clicks on each half. Since you mentioned 22 clicks per half, I assumed you used the same method. However, that copy/paste thing is nice
Highlighted
Sorry if I wasn´t clear enough. My target is to replicate sweep and revolved ends with minimum number of clicks/references. Ideally, creating a UDF that only asks for a curve and a plane.
I started with the sweep and then creating a revolve at the ends. But to do the revolve, I can use only half of the section, projecting the edges, creating a line in the middle and trimming the curves.
No problem until this point.
Now I try copy/paste to the other end, it asks me all the edges references, and it fails often. I do the revolve manually again, group all features and try to copy/paste using other curve, problems....
I try to copy revolved ends to other sweeps with varied dimensions, problems...
The trick here was to copy the surface, trim it by half, and use all edges for the revolve.
Now I can replicate the sweep with revolved ends just giving a curve, a plane and two endpoints.
I have parts where I have to make twenty or thirty sweeps like these, now I make them much more faster.
Jose
Highlighted
What if you change the order and put the revolves in first, and reference the tangent edges in the sweep?
