Color control when exporting to .dwg format
Dale_Rosema
Is there a place where you can control/set these parameters (globally) for every time a drawing is exported to .dwg format?
Thanks, Dale
1 ACCEPTED SOLUTION
dnordin
(To:Dale_Rosema)
Dale,
Try changing the word "white" to "7".
Also, double check that the file is being read in properly.  Check the trail file and/or the std.out file for any errors.
This is what we're using:
map_color       BACKGROUND_COLOR          7
map_color       DIMMED_COLOR              7
map_color       LETTER_COLOR              7
map_color       HIGHLIGHT_COLOR           7
map_color       EDGE_HIGHLIGHT_COLOR      7
map_color       GEOMETRY_COLOR            7
map_color       HIDDEN_COLOR              7
map_color       SHEETMETAL_COLOR          7
map_color       CURVE_COLOR               7
map_color       VOLUME_COLOR              7
map_color       SECTION_COLOR             7
map_color       PRESEL_HIGHLIGHT_COLOR    7
map_color       SELECTED_COLOR            7
map_color       SECONDARY_SELECTED_COLOR  7
map_color       PREVIEW_GEOM_COLOR        7
map_color       SECONDARY_PREVIEW_COLOR   7
map_color       DATUM_COLOR               7
map_color       QUILT_COLOR               7
14 REPLIES 14
dnordin
(To:Dale_Rosema)
Dale,
Use the config.pro option:
intf2d_out_dxf_mapping_file <full path to mapping file>
in the mapping file, you can define
map_color
map_layer
map_line_style
map_font
For example:
map_layer       DXF_AXIS                  1
map_layer       DXF_CONTINUOUS_LINE       2
map_layer       DXF_HIDDEN_LINE           3
map_line_style  solidfont                 continuous
map_line_style dotfont       dot
map_line_style  ctrlfont                  center
map_line_style  phantomfont               phantom
map_font        font                      verdana.ttf
map_font        filled                    verdana.ttf
map_font        isofont                   isocp3_iv50.ttf
Dan N.
Dale_Rosema
(To:dnordin)
Is there a particular extension that you need to give to this file?
.scl are system color files, is there something like that?
If I try it and it doesn't work to my satisfaction, is there a way to turn it off?
Dale_Rosema
(To:dnordin)
I created a file called:  dxf_export.pro
In that file I created a series of:
map_color geometry white
map_color hidden_line white
map_color sketch white
map_color curve white
map_color quilt white
map_color manufacturing_volume white
map_color sheet_metal white
map_color datum white
map_color letter white
map_color highlight_primary white
map_color highlight_secondary white
map_color highlight_edge white
Having saved it all. Exiting out of Creo/WF5.0 and getting back in (in order to set the config.pro and other files), when I exported, nothing changed.
Dale_Rosema
(To:Dale_Rosema)
Danilo Veljkovic
Are you still on the community site and could possibly help?
I have been reading through you thread:
dxf_export settings
dnordin
(To:Dale_Rosema)
Dale,
Dale_Rosema
(To:dnordin)
Daniel,
I changed the whites to 7's - nothing yet.
Do you see anything wrong/inconsistent with this:
Dale
Dale_Rosema
(To:dnordin)
Daniel,
I replicated what you had listed and it worked.
More out of curiosity, why are the parameter names you listed (which work), different then what was listed on my first post (which didn't work - yet are what shows up in the properties box   ).
Thanks for all your help.
Dale
Dale_Rosema
(To:dnordin)
Daniel,
Do you know what I would need to change symbols to white?
Thanks, Dale
Dale_Rosema
(To:Dale_Rosema)
I tried:
map_color   symbol_color   7
But that didn't work. Does anyone have other thoughts?
Thanks, Dale
open Creo dialog, where you can mix Creo system colors (geometry, curves, background, and so on) and try to find out which system color is associated with your symbol.
MH
Martin Hanák
Dale_Rosema
(To:MartinHanak)
According to this, the System Color is Intrinsic:
I tried:
map_color   intrinsic_color   7
but that didn't work.
Dale,
Intrinsic color tells you, that the symbol contains several entities and these single entities have different colors assigned.
To edit symbol definition:
  • open empty drawing
  • on Annotate tab, click Symbol > Symbol Gallery
  • in SYM GALLERY menu, click Redefine > Retrieve command
  • redefine the symbol
  • click Done to finish editing
  • click Write to save new symbol version ... save it into original location !!!
MH
Martin Hanák
Intrinsic is just a button/indicator for the original color(s) the symbol was created with.
It should be 'default' but there's not enough GUI style QC.
Dale_Rosema
(To:MartinHanak)
I did click on Color and change it to "Letter" and when it was exported, it became white
Now how do I edit the symbol in the library?
