Common name
Participant
Common name
Creo Community,
While creating a new part, below the "name" box is "common name". What
is common name
and how is it used?
Brad
Creo 2.0 M010
Common name
Common Name is used primarily in Windchill (where it is called "name"
confusingly). It allows you to use punctuation, spaces, capitalisation
etc to give the part/asm/drawing a more descriptive title. You can access
it in drawing title blocks (or any other notes) using &PTC_COMMON_NAME:D
(this will display the common name of the drawing, drop the 😄 to display
the common name of the active part.
cheers
Mark von Huben
Cochlear Ltd
Common name
See either of these doc’s.
It’s horrible that this confusing situation still exists.
Common name
Useful only with Windchill really
The basic idea is name=number in Windchill and common name=name in Windchill
