WF3, M170I have a part with an analysis feature that captures the area of a surface. That area feature parameter is used to create raised text on the part. I've done so by directly tying the feature parameter to the sketch text (see dialog box below). The parameter is also displayed in a 3D note.In the 3D note, the display is 3 decimal places however in the raised text it's 6 places. How do I limit the raised text to 3 places? <<picture (device=" independent=" bitmap)=">> Doug SchaeferThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
LinkedIn
