Coordinate system size
rizzari
1-Newbie
Hi Everyone,
Is there any way to make a coordinate system visualy larger, maybe my eyes are not what they used to be, but seeing what axis is what is difficult. Thanks.
Bob Rizzari
3 REPLIES 3
dmartin
11-Garnet
(To:rizzari)
Bob,
Olaf Corten would know this better than me, but I seem to recall a hidden config.pro option (you have to type it in manually; it's not recognized by Find or type forward) with a name like text_height_factor that controls how big alphanumerical annotations appear in the graphics area. IIRC, the default value is 50, and setting the value lower makes the graphics area text bigger. I believe the values can be changed from 0 to 100. I haven't used this since Wildfire, so hopefully someone else can chime in.
David R. Martin II
Senior Mechanical Design Engineer
Amazon Prime Air
Thom
9-Granite
(To:dmartin)
Is there a config option that lets you set the default Axis Length for the Display Zoom-dependent property of a coordinate system? Mine defaults to 37.060 (inches). 98% of the time I have to change it to 3.000. It would be nice to have that as the default value.
Thanks Dave,
The hidden config option text_height_factor worked to make the text large enough for me to read comfortably.
Bob
