Copy out Instance from Family table.
bbusschers
7-Bedrock
We have defined our labels with the use of a family table.
This family table is at this moment so big that we have trouble with maintaining the
instances.
So, we are thinking about separating the instances into independent parts.
What is the best way to do that, in combination with Windchill?
Thanks for the suggestions.
With kind regards,
Bert Busschers
Sr. Mechanical Designer/ Cad Administrator
ME/ID Department
[cid:image001.jpg@01CEBB64.B1857400]
Benchmark Electronics B.V.
Lelyweg 10 - 7602 EA Almelo - The Netherlands
+31 546 535 209 (tel)
Bert.Busschers@bench.com<">mailto:Bert.Busschers@bench.com>
www.bench.com<">http://www.bench.com>
MCAD Mananger Benchmark
bfrandsen
6-Contributor
(To:bbusschers)
Bert,
1. Check out generic and all instances.
2. Retrieve all instances + generic into session from your Workspace. This can be done in one operation by marking all objects in the workspace and select File > Open In > Open in Creo in from the workspace browser.
3. In Creo go to the generic and delete entire family table.
4. Save generic and all instances from Creo one by one.
5. Check in from the Workspace.
Best regards
Bjarne Frandsen | Technology Specialist, MCAD
Phone: +45 9684 4825 | Email: -
[cid:image001.png@01CDCC9C.5B8352F0]
Bang & Olufsen A/S | Peter Bangs Vej 15 | DK-7600 Struer | Denmark
www.bang-olufsen.com
+1 on Bjarne's response.
However, when this is done, what are the ramifications on any assemblies
that contained these instances, where the instances are swapped out via
Pro\Program. And in the use of the "Lookup_Inst" function in
assemblies where the parts are used. I welcome a response from PTC on
this.
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215 or 989.773.7981, ext 12484
Integrity, Commitment to Stakeholders, and Passion for Excellence
bfrandsen
6-Contributor
(To:bbusschers)
Without a try, I guess Pro/Program will report a failure. You will not get a warning from Windchill/Creo.
But if you use this functionality in Pro/Program you will not be interested in dissolving you family table in the first place.
If you want to be sure, you must investigate "where used" assemblies before dissolving.
/Bjarne
