Fredrik, Have you created cosmatic threads as seperate feature instead of creating it in hole? If yes then I think you could select cosmatic theards by selecting feature from filter and then trim it from new surface. Sometimes you can not select new surface as trimming surface at that time create a plane passing through the new surface and trim cosmatic. Hope it will help you in fixing your problem. Regards, Vimlesh Patelia, India.
