Cosmetic tread
SOLVED
Re: Cosmetic tread
Or like Milan, wordpad works, you may have to rotate your paper and turn off word wrap.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Re: Cosmetic tread
you can use any text editor, but i prefer to use Notepad++. See link:Notepad++ Home
The "messy" picture you show is actually also the laypout in my file the first time i opened it :-(. So i had to use tabulator to arrange it so it looked nice.
But Notepad++ i prefer also because it remembers all the text files you have had opened, so you dont have to look for them anymore (unless you really edit a lot of text files i guess). See in red below.
Re: Cosmetic tread
Thanks for your help. I have to change file with hole parameters like you.
Best Regards
Re: Cosmetic tread
Be sure to back up those files or move them elsewhere and point to them with a configuration option (assuming there is one).
It is too easy to loose customized files on Creo release updates if they are buried in the Creo folder structure.
Re: Cosmetic tread
Desired config options:
hole_parameter_file_path
Re: Cosmetic tread
That's the one, thanks
Re: Cosmetic tread
does it works in creo 3.0 also..??
Re: Cosmetic tread
to my knowledge it also works in Creo 3
Re: Cosmetic tread
Great Jakob
Even i tried this ,and it worked
Re: Cosmetic tread
Tabulator?  Where would one find that in Notepad++?
