I wish to create a mirrored sheet metal part which will be independent of the original part. Using 'File, Save As', the dialog appears as shown, but the system will not allow me to select 'Mirror geometry with features' and it will not allow me to clear the 'Geometry dependent' check box. Any ideas on how to do this please?
Hi Rob,
Unfortunately, this is not a functionality for sheetmetal parts. This is discussed in the following document:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS161580
Hi Rob,
