Hello Everyone,
Is there a way I can "abort" from a command?
I'm currently waiting for Creo 2.0 to calculate a shell feature on a part.
The task manager says the 4 cores are operating at about 8-12% power. I've been sitting here for about 45 minutes.
If I kill Creo in the Task Manager, I might need about 2 hours to redesign the part I was working on, but I'm not sure if Creo will finish computing anytime soon.
Help, please?
try clicking STOP button located in the botton right corner of graphic window.
MH
I am running Creo Essentials.
I'm not using Creo Simulate.
I am simply trying to shell a solid and Creo seems to take hours to complete the task.
Why are you asking about Creo Simulate?
I can't upload the model due to confidentiality.
I'm not concerned about making the shell feature work.
I want to find a way to abort the command when Creo gets stuck calculating the feature.
Is there a keyboard input which causes Creo to stop what it is doing aside from closing the software via the task manager?
MH
